And BobR is correct. There is only one reason that P/S and PS/B run BEFORE the fuel cars. The stands would be empty if they didn't. Every class from P/S on down is merely space filler between rounds of fuel.
Not true
The main reason PS run in front of the fuelers is because of the clutch dust the fuelers leave on the track.
