WOW .Magnum Force is the only one i have ever seen in use. Must 3-4 cars around here running them. Strip only and street/strip cars. All of them had re-inforced the shock tower. All of the owners seemed very happy with them.
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block."
Those words must have left a bad taste in his mouth!
