Many of those claims you make are off base.
Adjustable strut rods with bushings ARE a nice way to add some extra adjustment to your car for alignment.
There have been others that offer adjustable strut rods. Yours are not the first.
The stock forged strut rods have been fine strength-wise and proven in many cars that develop high cornering forces. Including dedicated track cars. Tim W with 275 wide sticky race tires has not broken or bent a stock strut rod. You might if you hit something you shouldn’t have.
The strut rods takes most of the forces from braking along with the upper control arm. Not much side load goes through the strut arm.
And adjustable strut rod is nice for fine tuning alignment. But relying on an adjustable lower control for all your caster adjustment could add to other issues.
Shortening the strut rod forward reduces the clearance between the tire to front lower wheelwell. This is the area most all older mopar run into tire rubbing in the front. If you shorten the strut rod 1", the tire clearance will be reduced at least 1/2". A litte more than 1/2" because the axle centerline is a little closer to the lower ball joint (LBJ) than the upper ball joint (UBJ).
When you use offset bushings or a tubular upper control arm made to add caster the UBJ moves back and actually increases tire clearance.
Also shortening the strut rod too much will twist the LCA bushings. The rubber can take more misalignmen, but the polyurethane LCA bushing is just a plain bearing. If you pull the LCA forward too much with an adjustable strut rod you will twist on the polyurethane LCA bushing. Might oblong the bushing.
If you want to retain a stock look and get the positive caster back for your car. We just developed an adjustable strut rod that you can install in about an hour that will do both. Here is some info:
NEW FOR MOPARS – Developed by DIXIE RESTORATION PARTS
ADJUSTABLE STRUT RODS FOR A, B, & E, BODIES
“ GET YOUR CASTER BACK”
OVER ONE INCH OF ADJUSTMENT TO GET BACK THE CASTER LOST BY INSTALLING POLYGRAPHITE OR POLYURETHANE ON SOME APPLICATIONS.
“BENEFITS”
* “NEW” MADE FROM VERY HIGH STRENGTH ¾ INCH MATERIAL * UP TO 5 TIMES STRONGER THAN STOCK RODS * MADE TO PERCISION SPECS., FOR STOCK LOOK AND FIT “ JUST LIKE FACTORY RODS” * NO NEED FOR OFFSET UPPER CONTROL ARM BUSHINGS * NO NEED TO BUY EXPENSIVE AFTER MARKET ARMS WITH HIEMS ENDS * EASY TO INSTALL * MADE IN THE USA BY CERTIFIED CAR NUTS TO ENSURE HIGH QUALITY
For you guys running larger than stock wheel tire combos, the forces exerted on your suspension during cornering is much greater with larger tires/wheels than the stock strut rods were designed for. These improved rods will easily handle those forces and allow for a more stable car at high speeds if you desire to adjust it as such.
If you want more info, call us or email us and we'll be glad to help. We sold out of all the ones we brought to both Carlisle and the Nats. You can use any brand bushing you want.
Thanks, Randy
Sorry for any confusion on my post. I responded to Domingo's original post about a low buck alternative to improve handling. If money is not an object, XV or Alterkation are good products.
We understand that we are not the first to offer adjustable strut rods. Nor did we claim to be. Other companies offer this product at various prices. We feel ours are of a higher quality than most, and are more stock in appearance than the others.
Hope this clears up any confusion.
Thanks, Randy
