ok - lots of forward progress, and taking the Dak to it's first '
o-fficial' trail ride tomorrow to Chinaman Gulch 👍 .
Shocks - done
Fuel filler neck dual-feed leak tested and functional - done
Rock sliders - done
Front winch - done
Bed inner wheel wells tacked in place - done
Drove it on the back roads a few miles to the nearest gas station - tested the shut-off valves and no leaks, then filled up the main tank until the handle shut itself off just like it's supposed to - that was huge 👍 .
Bolting together the space tire/wheel and installing the p-side seat today, and then I'll clean it off, then toss in all the gear for tomorrow's run to Chinaman
Steering is a bit 'twitchy' when trying to go straight - seems I may need to check the toe-in to see if the tires need a garage alignment - might be causing the 'twitchy' part, or else there's some other fine-tuning needed - TBD.
- Sam
