...crossing off the list of small stuff. Bolted on the Jegs "Magnum" thermostat housing (#53251), sensors installed in the intake, and got a 45* heater hose fitting to make connecting to the heater hose a cinch. Have a nice HVH "Super Sucker" 2bbl carb adapter ready to bolt on, and used a children's Tylenol syringe to pre-fill the ram and ram hoses - worked awesome, very little mess, exhaust is nearly done, fuel lines done. Getting close to plugging in the EFI wiring...and firing it up.
45* heater hose fitting from Discount Hydraulic Hose (3/8 npt x 5/8 hose) -
https://www.discounthydraulichose.com/product-display.html?Product_Code=4503-10-06Jegs Magnum t-stat housing -
https://www.jegs.com/i/JEGS/555/53251/10002/-1#
