...got the big hole in the bed covered up - ...and taking maximum advantage of every cubic inch of available space under the bed...this is what it covers...leaving the entire bed open for gear/sleeping/whatever - Look close - there's an inflated 40x13.5 Toyo in there - the tire edge 'is' the support for the big access door - works awesome -
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler' 52 Willys M-38 "Poncho"
