Cool - since magnum heads are apparently notorious for developing cracks I had my machine shop check 'em out, and horray! - no cracks!, and the guides were good too! - double woot!!
. While they had them they gave them a thorough cleaning, light re-surfacing, installed the fresh valve seals, and the new Comp Cams springs.
Note - being a magnum ya haveta drop in the lifters
before bolting on the heads...a rather important step I completely neglected to remember
But...in the process of sourcing another head gasket (
) I discovered that Fel-Pro has a 'Severe Duty' version of their magnum 360 head gasket, pn# 519SD (as opposed to the standard duty # 9898PT), so I opted for the SD gaskets for my engine. Chased all the threads, cleaned everything spotless, lubed the bolts with a light brush of assembly grease, sprayed the cylinder walls with a light coating of Amsoil Engine Fogging oil (to make sure the rings remain 'happy'), and bolted on the heads and valve train this morning. About 1-1/2 turns to secure the rockers and everything's looking good
Note #2 - the Fel-Pro severe-duty magnum 318 head gasket is pn# 540SD
