So I've considered my options, and I am looking into a "raised cowl" style 70 Roadrunner hood. Basically a 70 style power bulge hood with a flat top cowl, and insert the square Air Grabber door into it in a similar manner as the N96 hood. I'm looking for the cowl or power bulge to be wide enough to accommodate the factory oval air filter, and I will likely use an A12 fresh air base and hood seal to make it functional.
