Re: 540 aluminum block, MUST have 3x2bbl, fit 70 N96 Air Grabber
[Re: Twostick]
#2731359
01/09/20 10:27 AM
01/09/20 10:27 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
With an aftermarket block, why stop at 4.25 stroke?
572ci /4.5x4.5 bolts together just the same, but oil pickup may need to go external (which, once you have the aftermarket block is really easy given most aftermarket blocks have provisions for that built in).....Unless the appearance of the oil line is not desirable, which is understandable.
There are even shelf/stocking pistons for 572, both hemi and wedge with normal street compression ratios.
Rich H.
Esse Quam Videri
Entire Thread
BiomedTechGuy
01/06/20 01:25 AM
rb446
01/06/20 02:09 PM
BiomedTechGuy
01/16/20 12:05 AM
DaveRS23
01/06/20 02:34 PM
Cab_Burge
01/06/20 07:15 PM
hemi-itis
01/06/20 08:01 PM
BiomedTechGuy
01/07/20 03:26 AM
BiomedTechGuy
01/07/20 03:34 AM
AndyF
01/07/20 03:47 AM
DaveRS23
01/07/20 04:03 AM
BiomedTechGuy
01/07/20 04:47 AM
BiomedTechGuy
01/26/20 03:08 AM
Hemi_Joel
01/20/20 01:34 AM
Cab_Burge
01/20/20 04:08 AM
DaveRS23
01/20/20 02:47 PM
hemi-itis
01/20/20 03:26 PM
BiomedTechGuy
01/26/20 03:18 AM
polyspheric
01/07/20 07:01 PM
SCATPACK 1
01/08/20 02:53 AM
polyspheric
01/08/20 03:09 AM
BiomedTechGuy
01/08/20 03:19 AM
BiomedTechGuy
01/08/20 03:13 AM
GomangoCuda
01/09/20 04:41 AM
BiomedTechGuy
06/04/20 04:51 PM
GomangoCuda
06/04/20 07:27 PM
BiomedTechGuy
06/05/20 04:58 AM
BiomedTechGuy
07/24/20 04:45 AM
dvw
07/24/20 11:37 AM
07/24/20 11:38 AM
Dragula
07/24/20 02:58 PM
Cab_Burge
07/25/20 08:30 PM
BiomedTechGuy
07/30/20 04:21 AM
Dragula
07/30/20 04:00 PM
Cab_Burge
07/30/20 04:22 PM
BiomedTechGuy
07/31/20 11:26 AM
BiomedTechGuy
12/15/21 03:16 PM
ZIPPY
12/15/21 05:26 PM
BiomedTechGuy
12/15/21 06:07 PM
n20mstr
12/15/21 06:16 PM
BiomedTechGuy
12/15/21 07:05 PM
GomangoCuda
12/15/21 07:24 PM
JERICOGTX
12/15/21 07:36 PM
GomangoCuda
12/15/21 08:06 PM
GomangoCuda
12/15/21 08:33 PM
BiomedTechGuy
12/15/21 09:03 PM
GomangoCuda
12/15/21 09:17 PM
BiomedTechGuy
12/15/21 09:46 PM
GomangoCuda
12/15/21 09:58 PM
ZIPPY
12/15/21 10:31 PM
BiomedTechGuy
12/15/21 10:55 PM
ZIPPY
12/15/21 11:01 PM
BiomedTechGuy
12/15/21 11:31 PM
GomangoCuda
12/16/21 02:36 AM
BiomedTechGuy
12/16/21 04:10 AM
Brad_Haak
12/15/21 11:04 PM
ZIPPY
12/15/21 10:42 PM
ZIPPY
12/15/21 10:46 PM
ZIPPY
12/15/21 10:19 PM
BiomedTechGuy
01/08/20 04:55 AM
an8sec70cuda
01/08/20 02:18 PM
second 70
01/08/20 03:59 PM
BiomedTechGuy
01/08/20 05:46 PM
Twostick
01/09/20 02:31 AM
BiomedTechGuy
01/09/20 03:28 AM
BiomedTechGuy
01/09/20 06:37 AM
Twostick
01/09/20 01:48 PM
ZIPPY
01/09/20 02:27 PM
BiomedTechGuy
01/09/20 05:33 PM
ZIPPY
01/09/20 06:33 PM
polyspheric
01/09/20 04:19 PM
BiomedTechGuy
01/09/20 05:26 PM
Cuda_70
01/09/20 08:15 PM
BiomedTechGuy
01/10/20 01:40 AM
Twostick
01/10/20 04:11 AM
BiomedTechGuy
01/10/20 02:40 AM
SCATPACK 1
01/10/20 04:49 AM
BiomedTechGuy
01/10/20 11:08 AM
DaveRS23
01/10/20 02:41 PM
BiomedTechGuy
01/10/20 03:55 PM
CSK
01/10/20 05:54 PM
BiomedTechGuy
01/10/20 08:20 PM
Weiand P3690982 6bbl does NOT FIT N96 Air Grabber
BiomedTechGuy
05/31/20 07:54 PM
Re: Weiand P3690982 6bbl does NOT FIT N96 Air Grabber
Dragula
05/31/20 08:22 PM
jbc426
01/16/20 02:17 PM
nss guy
01/16/20 03:46 PM
ZIPPY
01/16/20 04:14 PM
hemienvy
01/16/20 04:28 PM
BiomedTechGuy
01/16/20 05:40 PM
BiomedTechGuy
01/16/20 05:43 PM
jbc426
01/18/20 08:25 PM
BiomedTechGuy
01/19/20 05:15 PM
BiomedTechGuy
01/19/20 05:19 PM
jbc426
01/20/20 04:56 AM
Weiand P3690982 6bbl intake HAS ARRIVED!
BiomedTechGuy
01/30/20 11:27 PM
Re: Weiand P3690982 6bbl intake HAS ARRIVED!
BiomedTechGuy
05/29/20 03:15 AM
Cab_Burge
05/31/20 10:40 PM
BiomedTechGuy
06/01/20 12:42 AM
BiomedTechGuy
06/02/20 12:44 AM
605ply
06/02/20 07:09 PM
hemi-itis
06/02/20 08:03 PM
BiomedTechGuy
06/02/20 11:19 PM
605ply
06/03/20 12:13 AM
BiomedTechGuy
06/03/20 12:41 AM
Cab_Burge
06/03/20 06:26 AM
