Re: 540 aluminum block, MUST have 3x2bbl, fit 70 N96 Air Grabber
[Re: BiomedTechGuy]
#2995455
12/15/21 11:16 AM
12/15/21 11:16 AM
Posts: 100 Louisiana
BiomedTechGuy
Louisiana
EDIT: NOT "my" block. Thanks to the forum for the info! What a difference a year makes... First and foremost, THANK YOU ALL for the conversation and advice. I see it as encouragement. The Bill Mitchell aluminum block is paid for, and that's as far as I've gotten. I've had a "vacation house" under construction and the thieving CONtractors and gypsy dope fiend "workers" plus the astronomical increase in materials has been a NIGHTMARE. It's now basically finished. I'm hoping the ModMan fits under my N96 hood, and I'd like to run a taller than stock air cleaner. I may be best served with an A12 type scoop, the taller one that's a bit bigger than the factory scoop. Some days, I just hope I can get the block built out w/in the next year or 2. Turning 60 at the beginning of 2022, having been to the funerals of 3 friends in 3 years, I know my time isn't infinite. All of the parts and systems that I wrote about are installed, and the Calvert split mono leaf springs were a big improvement. It's funny how you can't really tell your leaf springs are worn out until you see the effects at the track. I have had ZERO time at the track to make any adjustments or even try out my HitMaster launch control. The guy I mentioned that was using the Weiand on a stroker, with 3x 500 CFM 2bbl carbs he made, progressive mechanical linkage, has decided to go to a 2x4bbl because the Weiand (as has been mentioned here) is limiting his performance, in particular the RPM range. It's come to the ModMan, Indy has a CNC program for Max Wedge port size, and they only charge about $100 to do it. So I hope to make the time to be able to drive my Roadrunner again, get to the track and see what kind of times I can get with all the traction and strengthening aids that I had installed, see what the HitMaster and McLeod RXT dual disc clutch setup can do, and so on. Again, thanks for all the replies and advice!
Entire Thread
BiomedTechGuy
01/06/20 01:25 AM
rb446
01/06/20 02:09 PM
BiomedTechGuy
01/16/20 12:05 AM
DaveRS23
01/06/20 02:34 PM
Cab_Burge
01/06/20 07:15 PM
hemi-itis
01/06/20 08:01 PM
BiomedTechGuy
01/07/20 03:26 AM
BiomedTechGuy
01/07/20 03:34 AM
AndyF
01/07/20 03:47 AM
DaveRS23
01/07/20 04:03 AM
BiomedTechGuy
01/07/20 04:47 AM
BiomedTechGuy
01/26/20 03:08 AM
Hemi_Joel
01/20/20 01:34 AM
Cab_Burge
01/20/20 04:08 AM
DaveRS23
01/20/20 02:47 PM
hemi-itis
01/20/20 03:26 PM
BiomedTechGuy
01/26/20 03:18 AM
polyspheric
01/07/20 07:01 PM
SCATPACK 1
01/08/20 02:53 AM
polyspheric
01/08/20 03:09 AM
BiomedTechGuy
01/08/20 03:19 AM
BiomedTechGuy
01/08/20 03:13 AM
GomangoCuda
01/09/20 04:41 AM
BiomedTechGuy
06/04/20 04:51 PM
GomangoCuda
06/04/20 07:27 PM
BiomedTechGuy
06/05/20 04:58 AM
BiomedTechGuy
07/24/20 04:45 AM
dvw
07/24/20 11:37 AM
07/24/20 11:38 AM
Dragula
07/24/20 02:58 PM
Cab_Burge
07/25/20 08:30 PM
BiomedTechGuy
07/30/20 04:21 AM
Dragula
07/30/20 04:00 PM
Cab_Burge
07/30/20 04:22 PM
BiomedTechGuy
07/31/20 11:26 AM
BiomedTechGuy
12/15/21 03:16 PM
ZIPPY
12/15/21 05:26 PM
BiomedTechGuy
12/15/21 06:07 PM
n20mstr
12/15/21 06:16 PM
BiomedTechGuy
12/15/21 07:05 PM
GomangoCuda
12/15/21 07:24 PM
JERICOGTX
12/15/21 07:36 PM
GomangoCuda
12/15/21 08:06 PM
GomangoCuda
12/15/21 08:33 PM
BiomedTechGuy
12/15/21 09:03 PM
GomangoCuda
12/15/21 09:17 PM
BiomedTechGuy
12/15/21 09:46 PM
GomangoCuda
12/15/21 09:58 PM
ZIPPY
12/15/21 10:31 PM
BiomedTechGuy
12/15/21 10:55 PM
ZIPPY
12/15/21 11:01 PM
BiomedTechGuy
12/15/21 11:31 PM
GomangoCuda
12/16/21 02:36 AM
BiomedTechGuy
12/16/21 04:10 AM
Brad_Haak
12/15/21 11:04 PM
ZIPPY
12/15/21 10:42 PM
ZIPPY
12/15/21 10:46 PM
ZIPPY
12/15/21 10:19 PM
BiomedTechGuy
01/08/20 04:55 AM
an8sec70cuda
01/08/20 02:18 PM
second 70
01/08/20 03:59 PM
BiomedTechGuy
01/08/20 05:46 PM
Twostick
01/09/20 02:31 AM
BiomedTechGuy
01/09/20 03:28 AM
BiomedTechGuy
01/09/20 06:37 AM
Twostick
01/09/20 01:48 PM
ZIPPY
01/09/20 02:27 PM
BiomedTechGuy
01/09/20 05:33 PM
ZIPPY
01/09/20 06:33 PM
polyspheric
01/09/20 04:19 PM
BiomedTechGuy
01/09/20 05:26 PM
Cuda_70
01/09/20 08:15 PM
BiomedTechGuy
01/10/20 01:40 AM
Twostick
01/10/20 04:11 AM
BiomedTechGuy
01/10/20 02:40 AM
SCATPACK 1
01/10/20 04:49 AM
BiomedTechGuy
01/10/20 11:08 AM
DaveRS23
01/10/20 02:41 PM
BiomedTechGuy
01/10/20 03:55 PM
CSK
01/10/20 05:54 PM
BiomedTechGuy
01/10/20 08:20 PM
Weiand P3690982 6bbl does NOT FIT N96 Air Grabber
BiomedTechGuy
05/31/20 07:54 PM
Re: Weiand P3690982 6bbl does NOT FIT N96 Air Grabber
Dragula
05/31/20 08:22 PM
jbc426
01/16/20 02:17 PM
nss guy
01/16/20 03:46 PM
ZIPPY
01/16/20 04:14 PM
hemienvy
01/16/20 04:28 PM
BiomedTechGuy
01/16/20 05:40 PM
BiomedTechGuy
01/16/20 05:43 PM
jbc426
01/18/20 08:25 PM
BiomedTechGuy
01/19/20 05:15 PM
BiomedTechGuy
01/19/20 05:19 PM
jbc426
01/20/20 04:56 AM
Weiand P3690982 6bbl intake HAS ARRIVED!
BiomedTechGuy
01/30/20 11:27 PM
Re: Weiand P3690982 6bbl intake HAS ARRIVED!
BiomedTechGuy
05/29/20 03:15 AM
Cab_Burge
05/31/20 10:40 PM
BiomedTechGuy
06/01/20 12:42 AM
BiomedTechGuy
06/02/20 12:44 AM
605ply
06/02/20 07:09 PM
hemi-itis
06/02/20 08:03 PM
BiomedTechGuy
06/02/20 11:19 PM
605ply
06/03/20 12:13 AM
BiomedTechGuy
06/03/20 12:41 AM
Cab_Burge
06/03/20 06:26 AM
