Re: 540 aluminum block, MUST have 3x2bbl, fit 70 N96 Air Grabber
[Re: Twostick]
#2731308
01/09/20 02:37 AM
01/09/20 02:37 AM
Posts: 100 Louisiana
BiomedTechGuy
Louisiana
That's the nice thing about displacement, even when built mild enough for your grandmother it will still make enough torque to scare the $hit out of you if applied indiscriminately.
My 9:1 MP509 cammed 493 wedge made over 500 ft/lbs between 2000 and 5000, 600 peak @ 4000.
Kevin
"over 500 ft/lbs between 2000 and 5000" THAT is an enviable torque band, and great for a mostly street car, like mine 9:1 seems low, especially with aluminum heads, unless you are running regular vs 91-93 octane pump gas I will want a little more CR than 9:1 but I certainly don't want to have any problems with premium pump gas I'm looking for my stroker to displace around 540 cu in because I'm only building one, and running at the upper limits of a factory block (600-700HP) and trying to get a good factory block to do it with (I'm storing my current short block when the stroker goes in) I figure an aftermarket block is going to be great peace of mind, and I may as well make it aluminum, and the one I want allows for a 4.50 stroke without clearancing, has a 4.50 bore (w/room for a little more bore). So I figure a 4.25 stroke and 4.50 bore will have great torque and good HP with easy to live with cam and valvetrain.
Entire Thread
BiomedTechGuy
01/06/20 01:25 AM
rb446
01/06/20 02:09 PM
BiomedTechGuy
01/16/20 12:05 AM
DaveRS23
01/06/20 02:34 PM
Cab_Burge
01/06/20 07:15 PM
hemi-itis
01/06/20 08:01 PM
BiomedTechGuy
01/07/20 03:26 AM
BiomedTechGuy
01/07/20 03:34 AM
AndyF
01/07/20 03:47 AM
DaveRS23
01/07/20 04:03 AM
BiomedTechGuy
01/07/20 04:47 AM
BiomedTechGuy
01/26/20 03:08 AM
Hemi_Joel
01/20/20 01:34 AM
Cab_Burge
01/20/20 04:08 AM
DaveRS23
01/20/20 02:47 PM
hemi-itis
01/20/20 03:26 PM
BiomedTechGuy
01/26/20 03:18 AM
polyspheric
01/07/20 07:01 PM
SCATPACK 1
01/08/20 02:53 AM
polyspheric
01/08/20 03:09 AM
BiomedTechGuy
01/08/20 03:19 AM
BiomedTechGuy
01/08/20 03:13 AM
GomangoCuda
01/09/20 04:41 AM
BiomedTechGuy
06/04/20 04:51 PM
GomangoCuda
06/04/20 07:27 PM
BiomedTechGuy
06/05/20 04:58 AM
BiomedTechGuy
07/24/20 04:45 AM
dvw
07/24/20 11:37 AM
07/24/20 11:38 AM
Dragula
07/24/20 02:58 PM
Cab_Burge
07/25/20 08:30 PM
BiomedTechGuy
07/30/20 04:21 AM
Dragula
07/30/20 04:00 PM
Cab_Burge
07/30/20 04:22 PM
BiomedTechGuy
07/31/20 11:26 AM
BiomedTechGuy
12/15/21 03:16 PM
ZIPPY
12/15/21 05:26 PM
BiomedTechGuy
12/15/21 06:07 PM
n20mstr
12/15/21 06:16 PM
BiomedTechGuy
12/15/21 07:05 PM
GomangoCuda
12/15/21 07:24 PM
JERICOGTX
12/15/21 07:36 PM
GomangoCuda
12/15/21 08:06 PM
GomangoCuda
12/15/21 08:33 PM
BiomedTechGuy
12/15/21 09:03 PM
GomangoCuda
12/15/21 09:17 PM
BiomedTechGuy
12/15/21 09:46 PM
GomangoCuda
12/15/21 09:58 PM
ZIPPY
12/15/21 10:31 PM
BiomedTechGuy
12/15/21 10:55 PM
ZIPPY
12/15/21 11:01 PM
BiomedTechGuy
12/15/21 11:31 PM
GomangoCuda
12/16/21 02:36 AM
BiomedTechGuy
12/16/21 04:10 AM
Brad_Haak
12/15/21 11:04 PM
ZIPPY
12/15/21 10:42 PM
ZIPPY
12/15/21 10:46 PM
ZIPPY
12/15/21 10:19 PM
BiomedTechGuy
01/08/20 04:55 AM
an8sec70cuda
01/08/20 02:18 PM
second 70
01/08/20 03:59 PM
BiomedTechGuy
01/08/20 05:46 PM
Twostick
01/09/20 02:31 AM
BiomedTechGuy
01/09/20 03:28 AM
BiomedTechGuy
01/09/20 06:37 AM
Twostick
01/09/20 01:48 PM
ZIPPY
01/09/20 02:27 PM
BiomedTechGuy
01/09/20 05:33 PM
ZIPPY
01/09/20 06:33 PM
polyspheric
01/09/20 04:19 PM
BiomedTechGuy
01/09/20 05:26 PM
Cuda_70
01/09/20 08:15 PM
BiomedTechGuy
01/10/20 01:40 AM
Twostick
01/10/20 04:11 AM
BiomedTechGuy
01/10/20 02:40 AM
SCATPACK 1
01/10/20 04:49 AM
BiomedTechGuy
01/10/20 11:08 AM
DaveRS23
01/10/20 02:41 PM
BiomedTechGuy
01/10/20 03:55 PM
CSK
01/10/20 05:54 PM
BiomedTechGuy
01/10/20 08:20 PM
Weiand P3690982 6bbl does NOT FIT N96 Air Grabber
BiomedTechGuy
05/31/20 07:54 PM
Re: Weiand P3690982 6bbl does NOT FIT N96 Air Grabber
Dragula
05/31/20 08:22 PM
jbc426
01/16/20 02:17 PM
nss guy
01/16/20 03:46 PM
ZIPPY
01/16/20 04:14 PM
hemienvy
01/16/20 04:28 PM
BiomedTechGuy
01/16/20 05:40 PM
BiomedTechGuy
01/16/20 05:43 PM
jbc426
01/18/20 08:25 PM
BiomedTechGuy
01/19/20 05:15 PM
BiomedTechGuy
01/19/20 05:19 PM
jbc426
01/20/20 04:56 AM
Weiand P3690982 6bbl intake HAS ARRIVED!
BiomedTechGuy
01/30/20 11:27 PM
Re: Weiand P3690982 6bbl intake HAS ARRIVED!
BiomedTechGuy
05/29/20 03:15 AM
Cab_Burge
05/31/20 10:40 PM
BiomedTechGuy
06/01/20 12:42 AM
BiomedTechGuy
06/02/20 12:44 AM
605ply
06/02/20 07:09 PM
hemi-itis
06/02/20 08:03 PM
BiomedTechGuy
06/02/20 11:19 PM
605ply
06/03/20 12:13 AM
BiomedTechGuy
06/03/20 12:41 AM
Cab_Burge
06/03/20 06:26 AM
