First thing I’d do is get a performance calibrated 4160 carb body(like a 3310) and see exactly how the secondary idle ciduit is done on one of those, then duplicate it....... along with using a tunable secondary metering plate.
In the past, when I’ve used those with big cams, I’d just remove the plate and swap to a block...... and then add 4 corner idle. Which is also what the guy did to the carb in the link. However, neither of those things are legal for Stock.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
