I guess the question that may not have been asked is......
If it was idling fine before, with the blades in the proper position, mixture screws in the proper range, and it was starting well, had plenty of vacuum, etc....... exactly what was the issue you were trying to cure?
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
