If I'm thinking right...with the positive cable disconnected from the battery the test light should be between the positive cable and the positive post, everything should be de-energized...the light should not come on, if it does disconnect one wire at a time until it goes out, when the light goes out that would indicate your power drain/shorted circuit.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
