Having a 71, I can say it would be easer pulling the column and seats, rotating the dash down so you can get to everything and put the new back where the old was. Be sure to check the wires that run through the column cause that is where the voltage regulator gets its signal from. Be sure to buy a can of Dioxit 5 to clean all the terminals that get reused.
