Re: Data logger graph, interpret the first 60 ft?
[Re: gregsdart]
#2109422
07/13/16 03:44 PM
07/13/16 03:44 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
I would take a swing from the start..Full stiff up front, if you can tie ir down to little to no travel even better. I might go 1-2 sweeps from full stiff on the rear at first and then look at the data. I would agree as old as they are they are likely dead. Lower tire pressure as well in the rear. FWIW we run the NA car at 9.4-9.75 and that is a 29.5x10.5 tire, not a W.
As for the launch RPM there area few schools of thought. Some of the fastest cars out there leave as low as the combo will tolerate. Making a "run" at the convertrer. That number seems to vary combo to combo. I am a koolaid sipper in that theory myself with a converter car. We leave very low with the NA 10.5 car. I was a non believer until I did it with mine, ended up leaving at 3900 in a car that made no power below 7700. That led to the best ET's and quickest 60' times for me. The current car we leave at 4200 with a similar power band. Just something else you may or may not want to try.
You have a way to collect and read data now. That will help a ton. My guess is you will end up with new shocks, a lot less tire pressure and eventually a much looser converter...
Entire Thread
Data logger graph, intrprt the 60 ft?2nd try tomrow
gregsdart
07/11/16 04:45 PM
Monte_Smith
07/11/16 04:51 PM
gregsdart
07/11/16 04:56 PM
gregsdart
07/11/16 04:53 PM
cudadon
07/12/16 03:22 AM
gregsdart
07/12/16 04:02 AM
gregsdart
07/11/16 04:59 PM
Monte_Smith
07/11/16 07:01 PM
Al_Alguire
07/11/16 06:48 PM
gregsdart
07/11/16 08:51 PM
Monte_Smith
07/11/16 09:04 PM
Al_Alguire
07/11/16 09:29 PM
DavidDean
07/11/16 11:08 PM
gregsdart
07/12/16 12:04 AM
HR3128
07/12/16 12:28 AM
gregsdart
07/12/16 12:57 AM
CMcAllister
07/12/16 02:30 AM
gregsdart
07/12/16 03:00 AM
CMcAllister
07/12/16 03:14 AM
Al_Alguire
07/12/16 06:37 AM
Al_Alguire
07/12/16 06:40 AM
gregsdart
07/12/16 01:35 PM
Monte_Smith
07/12/16 07:17 AM
gregsdart
07/12/16 01:24 PM
Monte_Smith
07/12/16 05:33 PM
LA360
07/12/16 07:56 AM
Al_Alguire
07/12/16 07:58 AM
Al_Alguire
07/12/16 05:44 PM
gregsdart
07/12/16 06:54 PM
CMcAllister
07/12/16 08:20 PM
Al_Alguire
07/12/16 07:00 PM
Monte_Smith
07/12/16 07:00 PM
CMcAllister
07/12/16 07:04 PM
Monte_Smith
07/12/16 07:14 PM
FastmOp
07/12/16 08:17 PM
gregsdart
07/13/16 02:24 AM
Slingshot383
07/13/16 03:04 AM
gregsdart
07/13/16 03:56 AM
Monte_Smith
07/13/16 05:23 AM
Al_Alguire
07/13/16 06:33 AM
gregsdart
07/13/16 11:53 AM
Monte_Smith
07/13/16 06:19 PM
Al_Alguire
07/13/16 07:44 PM
gregsdart
07/13/16 11:01 PM
gregsdart
07/13/16 11:10 PM
MR_P_BODY
07/14/16 12:35 AM
Monte_Smith
07/14/16 05:26 AM
Al_Alguire
07/14/16 07:14 AM
Slingshot383
07/15/16 02:47 AM
cudabin
07/15/16 03:22 AM
Monte_Smith
07/15/16 07:52 PM
Al_Alguire
07/15/16 07:30 AM
gregsdart
07/15/16 11:28 PM
MR_P_BODY
07/15/16 11:52 PM
cudabin
07/16/16 01:50 AM
gregsdart
07/16/16 02:44 PM
cudabin
07/16/16 05:05 PM
Al_Alguire
07/16/16 06:27 AM
Monte_Smith
07/16/16 07:04 PM
cudabin
07/16/16 07:39 PM
Monte_Smith
07/16/16 07:47 PM
gregsdart
07/17/16 09:16 PM
gregsdart
07/20/16 01:28 PM
Forest
07/20/16 04:02 PM
Al_Alguire
07/20/16 05:44 PM
Re: Data logger graph, interpret the first 60 ft? update;video
gregsdart
07/22/16 05:43 AM
gregsdart
07/28/16 11:27 PM
moparx
07/29/16 02:04 PM
Re: Data logger graph, intrprt the 60 ft?2nd try tomrow
turbo toad
07/31/16 03:57 AM
gregsdart
07/29/16 02:19 PM
moparx
07/29/16 02:38 PM
MR_P_BODY
07/29/16 05:18 PM
Monte_Smith
07/29/16 04:56 PM
gregsdart
07/29/16 07:30 PM
gregsdart
07/29/16 09:22 PM
cudabin
07/31/16 12:20 AM
gregsdart
07/31/16 03:38 AM
fast68plymouth
07/31/16 05:15 AM
gregsdart
07/31/16 11:53 AM
gregsdart
08/26/20 02:35 AM
