Quote: as for fit, you can use a drop base and your stock lid. Paint the base black and roll. I had a CH4B 1/2" spacer and 625 Carter on my GTX w/ Stock assembly...well 2/3rds anyway. I ran a drop base, painted black. I Also ran the same set-up on a 67 Coronet w/ a Holley 750DP and it fit as well.
What drop base did you use that the lid . or at least the filter from that assembly and fit ???
You also must have ran a banjo fitting on the inlet of that carter , a stock factory line doesn't work with a drop base ...
It's real easy to say yes it can be done , what parts were actually used ???
The drop base was a summit piece. I might of had to buy the entire air cleaner. Keep in mind this was 10-12 years ago. As for the Holley I turned the fuel line backwards towards the fire wall. The fuel line ran up the back of the block, not the front. I believe with the Carter I bent up my own fuel line.
