Quote: Ok, I might have a line on a barely used Holley SD dual plane and Holley 650 vac sec. I am hoping that will fit and wont have the same fuel boil issues a Eddy does.. Was also told that 440 source had good heads that look stock when painted turquoise...
easy killer lets fix what you have now 1st. EVEN with that carb it should run pretty well. Does the SD have the stock coil mount location?
I think the answer is no and I would have to maybe get the six pack bracket or make one. I also now think this one may be a hair too tall. Do you know if the M1 bolts up to a holley??
