Edelbrock: Good for drivability and around town. Down on horsepower when compared to other brands.
Holley: 3310 750cfm vacuum secondary used to be my default carb for a mild street 440. They make good power and get good mileage almost out of the box. I've gotten 14mpg on the highway at 70mph with 3.23's and ran 13.5's at 104mph with a VERY mild combo, stock intake and horrible 60 ft. time. 9.5:1 CR.
Demon: Yes, they had quality control issues there for a while when Barry Grant still owned them (metal shavings) but they are a good carb. I got ahold of a Speed Demon and it's starts and idles when cold much easier than the Holley. According to some of the dyno tests in the archives it flows better and makes more power than all but the best aftermarket carbs as well. I'm very happy with it and wished I'd tried one sooner!
Good info. I will be lazy and ask if the Holley 3310 needs an adapter for the stock iron intake or the Eddy CH4B? I assume it does.. Also, I have never blocked off the hot air crossover on my steel intakes, but will I need to on an Aluminum one? Probably definitely with the Eddy, right? There is a CH4B on ebay now that has the crossover welded shut already.
you need a SPACER for a holley on a 67-69 stock intake but not on the CH4B , blocking the crossover is a good idea considering how easy the gas boils , but not necessary. You can just run a valley pan that is blocked.
