I have around 13.5 comp. I was having trouble figuring out a cam for my car, so asking here, Koffels, and comp, I had this special cam built for the car. This being my first B1 engine. I wasn't sure what to have built, it being a 4.37 bore 7.1 rod and 4.25 stroke. I bought a 6200 stall for my glide off of Chrisbarracuda since it was recomended for this cam grind.
Does this look like a good combo?
.775 in .766 ex timing at .050 int 29 btdc 75 atdc exh 82 bbdc 36 atdc 113.0 intake center line Dur. at .050 int 284 exh 298 lobe lift .4560 exh .451 Lobe seperation at 113.0
I use 1.7 rockers, How does this combo look to some of you guys? Is it a good choice? Or does anyone see room for improovement? I'm just starting to run bracket races with my car and still tuning. Car is around 2750 lbs. It feels good to me, for what I built ?
