Quote: Mike; The 1500# GVW weight on my trailors registration indicates the weight of the trailor only and not how much in can carry.
On my truck itself the Factory GCWR can be differ from 9000# to 13500# depending on the axel gear and engine combo.
With my 5.4 engine, same truck, same axel it can differ from 10000# to 13500# based on the gear only. Lie about your gear or change the gear or "door sticker" I guess you could change your Factory GCWR but not your GVW. mike
My truck is a 95 Dodge diesel duallie with the biggest tires, 6 speed stick and 4.10 gears. I will have to look at the door sticker to see what it says
