According to Pa.Dot it doesn't matter wether your private,commercial,or other wize,you must be regestered for your Gross combination weight if you pull a licenced trailer and the combination weight exceedes the gross weight of your tow vehicle.IE: if you have a truck that has a GVW of 10,000lbs and are towing a trailer with the laden weight of i0,000lbs you should register yourtruck for a GCVW of 20,000lbs,Rembember also any trailer over 10,001lbs or any truck or truck and trailer exceeding 26,001lbs requires a CDL licence and a health card. Also you must have a statement from the mfg as to the max combo towing weight.IE: My Dodge 3500 is 12,200GVW with a max towing GCVW of 23,000.I can't register my truck any higher unless it is modified and certified to do so.It is all based on axles,tire contact patch,braking capabilities,and structual design.
