I plan on using their cam in my stroker so............
If your Edelbrock heads are still coming to MY shop next month for porting, they will NOT be leaving here with Hughes valvesprings. Whether you want to use one of their cams in your engine, that is up to you, but I will use a Comp Cam valve spring on them.
