I reached around the tire with it on, to access the cam bolts. I like your specs, do you have stock upper arms? If so, you might have trouble getting 3+ caster.
Mostly metric tools?
I'm running the tubular uppers from somewhere, I forgot where I got them. ![](/ubbthreads/images/graemlins/smile.gif)
With good tubular uppers, you should be able to 3+ deg positive caster. The 1/4 camber split is for road crown.
What was the name of shop did you got it aligned?
Take it to Bagge Alignment on Washington Blvd just a few blocks east of Overland. http://www.baggeandson.com/ (310)838-8485 Right accross from MGM studios.
They have been in business for over 90 years. Tom Vardon is a descendant of the original owner. The alignment guy, Paul, has been there for over 30 years. They fully understand custom and handling alignments.
My dad has been going there since the early 60's. We just had car aligned there last week. Tell them Dave Wall sent you (my Dad).
I think I have recommended them to you before.
You've got the silver 71 or the butterscotch 71? I get those two owners mixed up here on Moparts.
