Quote: Would the above alignment specifications you stated be the same for a daily driver with radial tires and no drag strip racing?
I'll set up a daily driver for as much caster as I can get without sacrifcing camber. Camber I like to see at 0 to . 5 deg neg. no more than a 1/2 deg split between camber/caster. Toe I want at .06
