Would the above alignment specifications you stated be the same for a daily driver with radial tires and no drag strip racing?
Yep, I run radial tires and no drag strip action.
I ran that when I daily drove my cuda to work 80 miles round trip to work every day. Alignment done by Bagge & Son (since 1918) on Washington blvd in Culver City. Spec sheet:
Caster: 4.4 postitive (as much possible, I run offset UCA bushings #7103)
Camber: .5 negative
Total Toe: 0.12 ~1/16" toe in
I don't drive the car daily now. About 5,000 miles a year max. So I can get away with a more aggressive alignment
My current setup
Camber 1.5 negative
Caster 4.5 postive
Total Toe: .12 deg in ~1/16 toe in
That is a LOT of negative camber for the street. I don't know if I'd go recommending that. I drive so hard I always wear the outsides first anyway. So maybe I get 30K miles instead of 50K miles out of the tires. That will still take me 6 years to do. Heck, they'll probably rot by then.
Alignment below done by Cars Muffler in Redondo Bch. Not me in picture.
