Get rid of the over-center spring on the clutch pedal under the dash! That is the starting point. I had the same problems until I got rid of the spring in my Dart. After that it was cake to adjust. Feels like a normal clutch then also. Plus make sure your geometry is correct in your Z-bar and other linkage. It all works together.
