May have to remove the large over-center spring on the pedal assembly. I had to do this on my duster so the clutch had some "feel" to it after I put the Mcleod DD in.
I tried both. When I removed the overcenter spring it was even worse. The clutch pedal wouldn't return to the top, only part way. You would have to pull it back up.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
