Quote: Do you have a small return spring on the fork?It should have one.Rocky
Yes it has the small return spring. It's brand new but it still isn't enough to pull the pedal up. Even if it did pull it all the way back, I still have basically no pedal until it is almost at the floor.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
