You did say you had a small block in the car didn't you and now you have a big block, but are using the same clutch linkage Z-bar?
Also, you are running a 700 hp hemi with a stock bellhousing? That's just plain crazy! Have you ever seen a car that had a clutch explode? it does happen.
