That's a good place to start if the lugs drop down in size at or before the hub surface. A 1/2" lug is under .500" but you need to be dead on with your new lug holes. 5 thousandths is pretty tight if the holes are off.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind. - Stu Harmon
