Quote: Those rotors are pretty flat too...probably have to make sure you use a wheel with a thick enough mounting pad to get the spokes,etc far enough away for caliper clearance, or just wheels that curve outward somewhat.
They are a little thinner than the ones I use, so at least that helps offset the weight with the extra diameter.
A wheel like this may help. It's from Volk Racing, I believe...
