As long as you don't might the weight of a rotor that size may be, or running the 19" or 20" wheels...sounds like a decent deal for rotors and calipers (depending on just what Brembos they are?)
I stick with 360mm rotors on mine along with the 8 piston Brembos as I don't want to run larger than an 18" wheel on my car..
