You can probably find a cheapy china 2 piece cast wheel like would go on a Jeep, etc in a 19" maybe that may clear ? the problem is getting the offset you want I would guess at though?
A 2 piece wheel will let you get the offset just where you want it, but cost will be higher of course and as mentioned..you just need to watch for caliper clearance.
With a pretty 'flat' rotor like the specs on the ones you picked out, is it pushes the caliper further out towards the wheel. Again not the end of the world...you just have to plan ahead for the entire combo.
And the larger the wheel is...the slightly more forgiving the shape of the spokes,etc will be to the caliper clearance. The smaller you try to go the more critical it will be.
PS. You could always ask them if they know if their wheels have caliper clearance for the SRT Jeep...but who knows if they will know off hand?
