Mr. Moore,
Look at your two pictures were the front and rear seat elevations align with the door panel pattern on the pass side door panel. Look to be nearly identical As far as how far you squish the seat down when you sit in it, I have seen a variable there, regardless of seat design, simply because some springs are more worn/softer than others, plus the difference in foam seat padding or springs added (or not) when new seat covers are added.
