Today I was able to get some little things done. I installed the dual exhaust bracket, tip hangers, brake hose bracket, pedal assy, dome light wiring, fender splash shields, axle bump stops and the k frame bolts. I got my tie rod sleeves into the evaporust which revealed some yellow paint on one end of each assy. I also cleaned some of the buffing compound off of a few areas, It felt good to take parts out of the "ready to be installed" totes and throw away some empty bags.
