Did you notice the last 340 engine that I picked up was cast the exact same day as yours? It was assembled only one day before yours as well? Yet based on the VIN sequence on mine it ended up sitting around the LA plant for a month after yours was installed? Check out some of the date codes on the other engine parts and see if yours are the same or similar.
