Thanks Scott Any updates on your Duster?
The upper hose turned out pretty good, the bottom, not so good. I let it sit too long after painting/ dyeing it (Daughter wanted to swing). I'll redo the bottom one tomorrow.
I also started back on the grille. All the cracks are fixed (again ) and I'm down to spot putty. Primer and paint should happen this week.
Tonights project....
