when installing a battery for an old neighbor lady in the dark do not first connect the neg, then the positve and while tighening the positive terminal short your wedding ring on the wrench you just turned and touched the fender with. Did you know 14K
is one of the best conductors of electricity? did you know that in a few seconds it will glow? did you know when you finnaly get it off it will leave 2degree burns on your ring finger and the two fingers you pulled it off with? Did you know it was easy to find in the dark because it was still glowing? Dont ask me how i know
Remember remember the 11th of September, of murder and a terriosts plot. I see no reason why this treachery should ever be forgot.
