Quote: If you don't put a bowling ball into a bowling ball bag before you put it in the trunk it will roll from side to side with every turn and dent you trunk from the inside out (at least that's what I heard).
buying a set of 3.91s and driving home with them in the trunk can result in dented quarter panel.
pulling the fuel sender out of a 57 ford pick up then using a match for a light to see if you have enough gas to go cruising will result in a blow torch effect inside the cab!
getting a closer look at the green stain on one of the ribs of a "fit all" radiator hose isnt a very good idea, especially if the car is at 210 degrees, your not wearing safty glasses and you have your face 6 inches away from green stain. and never never trist the hose to see if its acually a coolant leak! . that might hurt very badly for several days!
never "feel" your brake rotor for scratches through the holes in your wheel with your finger right after going down a steep hill in stop and go traffic.
