Quote: got the pump and float deal worked out, and decided to pressure wash everything, since it was all accessible. being almost 80 degrees out, didnt hurt either.
is that the stock rear shackle set up on that dak?
looks like the shackle flip on the d150 when done.
and that looks like 43" spring perch centers from here. correct?
Fl is great in winter time.
if you are by yourself, who is under the truck and who is taking the pics? you said the help IN the bed was not helping?
