How about some help with where to install the valve springs:
Springs:
PSI DR426RML
1.500"
300Lbs seat at 2.050”
840lbs open at 1.150
Rate 600
Cool bind 1.100
Cam:
.767/.767 276/288 110 lob sep 108 centerline
With them installed at 2.050 they will be .183 from coil bind and I think you want to be closer to .050 from coil bind correct?
But if I install at 1.917 (2.050 - .133 (.183-.050)) that will give me 380lbs seat and 940lbs open pressure and that sounds like too much, thoughts?
