How did the bars work for you? They don't have a left or right and the hex ends are not clocked. I am going to order some Viking shocks to try with them.
Definitely stiffer than my MP .99 T-bars. I think the Bilstein RCD's helped.
I believe? Evan has run them on his 66 Cuda with RCD's and than Fox's with no other real changes. If so, maybe he can comment on the street ride and handling difference between those two shocks with 1.14" T-bars.
Yes as Steve suggested I have run these bars with both the Bilsteins and the Fox shocks. I haven't messed with the adjustment much yet, for the most part I left them on the firmest setting. The difference between the two is a smoother ride, very firm but not jarring, they hold the car up very well, its a more balanced feeling. The Bilsteins are a very good shock, a massive upgrade over the KYBs for sure. I will say on a street car on full firm setting on the front don't try to take of too quick as they really pin the front end down with the big bars, no weight transfer at all but that's not what I am trying to do with my car.
