Hey Evan...Good to hear from you!
I loved seeing your car on the track. I was just looking at some video I shot that day. I didn't get much but I did see a quick shot with your car in it.
The GoPro I had didn't record anything! I thought I set it up right but when I connected it to the computer, I saw nothing but what was on it before. Pisser.
My car is sitting now while I swap to a different cam. I was running a big Lunati that made great top end but felt soft under 3000 rpms. I slipped in a MP 528 solid. Valves are lashed but I had to order gaskets before getting it back together. It should be better suited for street and road course with the smaller cam.
I saw some video to, your car passing mine....Sounds like you have been busy on the Charger for next year. I was running 4:30 gears with a 286 Comp roller cam when we were out having fun so the rpm was always above 3000 if I ran in forth gear, just pulling 6500 on the straight and lifting. I tried 6500 in fifth once and was looking around for a roll cage and didn't see one so thought that might not be the best thing to do. I think your cam choice is a good one for what you are trying to do for sure.
