It seems like you are touting some implied benefit of a front to rear weight transfer. This is important in drag racing but I see little benefit in a street and road course car. If the front lifts and the rear squats on straight line acceleration, that is fine. If the same conditions occur when powering through turns, your steering geometry just changed and you either understeer MORE or oversteer and spin.
