You don't really want the Lincoln Versailles rear brakes. I used a Versailles housing in my car but the brakes are almost as expensive as a Strange setup after you rebuild everything. The rotors are directional and cost about $135 each and the calipers are really heavy and I doubt if you can even get them in a remanufactured form anymore. The housing also uses weird bearings too. Gus
