Quote: Are we bracket racers or professional racers. Why do you want to change gear sets. If you run low 8ths or faster run the 9 and keep a wad of money ready. The dana, easy set up for 4 to 8 hundred bucks unless you need new parts.Set the gears up right and make sure its straight and it will last for years with no upkeep and one thing less to worry about.Funny, we go to the track and guys are adjusting valves,charging the battery,changing jets,resetting the bars all kind of stupid stuff,why? Don't make it complicated!
Why would I need a wad of money? A properly set up 9 inch is trouble free.
How would I brace a Dana 60 for radials? You know a radial is a dead hooked tire.
Brett Miller W9 cnc'd heads STR Chassis fabraction
