i just duct tape an old bubble tire balancer to the windshield and bounce the car until the bubble faces 65 degrees to the southwest.....then subtract for humidity and headlight angles..... DONE . pinion angle set.
And if you take muffler angle into the equation...you're doing it wrong.
