If you build a chassis car with zero angle through both U-joints at load, the pinion is aligned with the transmission under power.
If you move this rearend downward 2", the pinion is parallel to the transmission. The result is the straightest, most efficient driveline set up possible for a 2-joint shaft when the transmission and pinion do not operate on the same plane.
