Quote: What is the tool that Quicktree uses to set pinion angles? Quicktree.
Yep quicktree is the tool to use
got to wonder,is there any kind of ban on exporting the famouns quicktree tool incase i ever need to get my pinionangle set right?
watch it, i may just send you my tool
Man no one ever needs to hear or even think of that!
The real way to set pinion angle is to adjust the front ride height until the pinion is at 3 degrees down or 7 with a leaf spring. If you can't get the front low enough then raise the back!
you know what I really think about pinion angle some of these guys still don't get it..
